That is amazing jose, very interesting to learn that. You probably know as much about this circuit as anyone these days. Nothing like building something to really gain insight. If R9 is passing 18mA, it's only a 1/4 W resistor, I wonder how much headroom that leaves before it overheats. I'll have to mess around with the power equations/ohms law, but it would be interesting to know how many watts with that current, at 62 V, would need to be dissipated.Hi JR,
I am sorry about his set back. R9 is supposed to be a 66.5 Ohms and it is passing some 18 mA if I understand the circuit correctly. Check Q9, Q10, and the two gate resistors.
Let me tell you that I have tested the adjustment procedure on a prototype that I built by copying the schematic for the ST-140. I could adjust the idle current as well as the DC offset without problems, without signal generator, without dummy load. I just used two DVM, but this may just as well be done with only one.
I built my prototype with things I had laying around, scavenged some parts from junk PCBs. I only tested it with +/-36V. because i do not have a suitable transformer to generate +/-62v. I can confirm that after I adjusted the idle current to 100mA on the negative fuse, and adjusted the DC offset to some 10 mV, i tested it with speakers and I could play music on it. Sounds all right considering my crude prototype.
1/4W should be fine. Please don't forget to check Q9, Q10 and the gate resistors which should be 1000 Ohms. Always back P2 so that the parallel combination of P2 and the 475 Ohms resistor give you some 60-75 Ohms before powering on to prevent turning it on with too large of a bias current. If your DC offset was correct, i think it should be close now so no need to touch P1 now.R-9 was replaced with Vishay 1/4 W metal film @ 66.5 ohms. I'll try the process again tonight and monitor the temp of R9. Stay tuned.
Good point jose, I did notice that R10 was not hot like R9. R11 is very close to spec at 401 ohms. I am confidant at this stage of the game, that ALL the transistors are the right substitutes and oriented correctly. More to follow, and thanks for your study of my efforts!Hello Ray andJR,
R10 should not be passing much current unless something is not right either at Q8 or Q9 orR11. What do you have installed for Q8 Nd Q9?. Are they correctly oriented?. Also is R11 (going from Q8 emitter to V-) 402 ohms?.
All knowledgeable comments jose. Let's see how my next attempt at biasing on the right board goes, and we may re-visit these measurements. Thanks, as always. We'll get 'er right.Q10 and R9 getting hot means a large current passing through them. That current can only go through q8 and Q9 but this means that P2 should also be passing that current in which case P2 and the parallel 475 oms resistor should also be getting toasted. If all is normal along P2, then your N channel is a suspect, because the gate should not take dc current because it should look like a capacitor unless your 2sk136 is doing something funny...
If I were you i would do the following measurements when your amp. powered at 70V on your variac:
1-measure the voltage drop across R9. Determine te current passing trhough it.
2-measure the voltage drop across the 2sk136 gate resistor. Determine the current. There should be no voltage drop there.
3-measure the voltage drop through pins 1 and 3 of P2. Power off, and measure the resistance between pins 1 and 3 of P2. Determine the current through it.
My expectation is that the current through R9 should be equal to that through P2.
