JR Harley
Just as a point of note, my mains from the wall averages about 119 V, often as high as 121. Stay tuned.To JR,
Lets make some further reasoning aling my last post. You said that you applied 70V with the variac. If i take the mains in your country to be 115V, then instead of having +/-62 Volts at the ouput of your power supply, you will have only +/-37.7 V. which is very close to my prototype running at +/-36V. Then my measurements should ve very close to yours.
1-
I adjusted my idle current to 110mA. DC offset adjusted to zero.
2-
Then my R9 (69 ohms) had 1.195 volts across. This is some 17.5 mA. In good agreement with my calculation of 18mA that i mentioned before.
3-
My P2 and its parallel installed resistor combination measures 77 ohms, and i registered a voltage drop of 1.353V across it. Thus 17.5 mA are passing through it. Just as expected.
4-
When i measured the voltage drop across the ends of either of the gate resistors (1000 ohms each) i get zero volts, thus no gate current. Again this is to be expected at idle.
Q9 and q10 get barely warm. nothing to worry about.
You can try to bring down the idle current to 110mA and do these measurements and compare to my values.
jrh
take your time.
