You have the DMM range in 20 V. So 0.26 is 260 mV. Interesting because up to now left-channel (vR1) bias would not adjust to above 8, which we can assume now was 80 mV. And now it will not go under 260 mV.
I am afraid to get any where with this you will have to get your head around what is happening when you adjust settings and replace components.
Example: I informed you to set the bias all the way down (adviced by Hyperion before after you mentioned the pulsing DBT).
Other example: I informed you about the range settings on your DMM for the resistance measurements. You did not reply, or even remeasured the resistors.
And I am not bashing you, believe me.
But for this to get to a positive ending you will have to check if what your doing is correct, and if you don't know, ask.
Counter clockwise as the starting point in bias settings implies the lowest possible value, so you turn clockwise to set it higher.
Does this mean this were the lowest values you could get it to or was the value going up turning the be clockwise? Make shure you can find the right information!
