We are getting .437 both ways when measured at 2k ohms.Try with range set to 2 kOhm. Can be that both divisions are higher then 200 Ohm. The 4 ohm measurement is for the two leads connected with the track.
Do you think it could be the pot itself? Or is .437 ohms working? It’s definitely a problem on this channel?Try with range set to 2 kOhm. Can be that both divisions are higher then 200 Ohm. The 4 ohm measurement is for the two leads connected with the track.
So this reads as x.437 kOhm.Or is .437 ohms
Do you think it could be the pot itself? Or is 437 working? It’s definitely a problem on this channel?
with the board connected and power on to the DBT I’m sure I could rig it up to be able to test underneath. I’m not sure what you mean by ground potential? What setting on the MM should I put it on? I found both R29-30 on each side of the board. You want these tested with power on connected to DBTThat looks ok. It's a 470 ohm variable resistor turned all the way to one side.
So although sometimes resistors can change value under load we are just going to assume for now the vR is good.
Next step.
I don't know how accessable the power board is for doing measurements with power on ( so the board installed )?
Can you measure the voltage from R29 to ground potential and from R30 to ground potential? On the high side ( towards the outputs)
This is interesting. If I have board connected, power on, and set my MM to 2K ohms and put both my leads on R23 (right next to R29) the DBT bulb dims. It would be the red,purple, yellow resistor. The DBT doesn’t dim all the way down but it dims. Does that mean anything?Range on 2k Ohm, so x.xxx kOhm.
So 437 Ohm
I’m taking this as I made a major mistake and the DBT dimming means nothing. Regardless I now know never to measure ohms on a live circuit.I'm interjecting here because GrisPato appears to be away from his pc. You cannot apply a multi-meter in resistance test mode to a live circuit. You are at risk of blowing the meter or the circuit (or both) you are testing. The meter (in resistance mode) applies a voltage (about 1v usually) to the circuit so any resistance reading you get will be meaningless anyway and in this case you are in the middle of a bias circuit so could cause it to runaway. In the event it seems to have shown a response from the bias network.
Thanks for that.I'm interjecting here because GrisPato appears to be away from his pc. You cannot apply a multi-meter in resistance test mode to a live circuit. You are at risk of blowing the meter or the circuit (or both) you are testing. The meter (in resistance mode) applies a voltage (about 1v usually) to the circuit so any resistance reading you get will be meaningless anyway and in this case you are in the middle of a bias circuit so could cause it to runaway. In the event it seems to have shown a response from the bias network.
Just see did now. Now I understand.I’m not sure what you mean by ground potential?
This is what we do next. So power off, measure the ohms at 2k of R23 and R25?Thanks for that.
And although a not adviced experiment it may be giving us a lead to investigate.
So let's power down the amp and measure the resistors compromising the bias network R23 and R25. And right away the bias transistor Tr 05.
Slightly confused. I always put the black lead of the mm on one end and the red lead on the other end of the resistor. Do we not want 2k ohm power off measurement of R23 and R25?Almost.
To be completely clear, measure from one leg of the resistor to the other. Range depending on expected value then adjusted for a reading.
Yes, from one leg to the other leg.Slightly confused. I always put the black lead of the mm on one end and the red lead on the other end of the resistor. Do we not want 2k ohm power off measurement of R23 and R25?
R23 measures 4.67-8 at 20k on the MM with power off to the board.Yes, from one leg to the other leg.
R23 should be 4k7 ohm so you will need a higher range then 2k.
And realise, we are looking for out of spec components. So we range in to get a reading, then use the range to know what it says.
Embarrassingly I can’t find R25. I’m still looking.And R 25?
Could be the bridge rectifier, (D601 & D602) but somewhat more likely to be Output Transistors - or damaged bias components causing OP transistors to run too much current.![]()
