Not well versed in the mathematics of this but TR05 has to turn on HARD to turn the bias down. The things that might prevent this is a faulty TR05 itself, OR out of spec resistors around it, including the trimmer VR01. If the bias is running too high then TR11 and TR13 are turned on too hard - if their bases are allowed to float towards the rails (voltage wise) high bias current will be the effect. But with TR05 in charge, 'turned on' and shorting the bases of TR11 & TR13 together that shouldn't happen.
OR there may be faulty components in the following parts of the circuitry, not so much TR07 & TR09 as these are concerned with overcurrent protection for the output transistors, and aren't usually a problem.
I hope this helps.
