1-2 is 0So practically no change.
Could you try to measure vR1 with different positions ( remind the one position you started with yesterday)
From leg 1-2 should be 0 ohm, from 2-3 should measure 470 Ohm with the trimmer turned clockwise and close to 0 turned counterclockwise.
2-3 is 0 turned counter clockwise
2-3 turned full clockwise doesn’t register unless I bump the MM up to 200k and then it bounces all over the place. From 11.4 to 19.4 and everything in between. It never stabilized.
