Yeah, let's try that. Keep your finger on the switch, if the bulb doesn't go dim in 2-4 seconds switch it of. ( I do think you're going to be ok)
When the bulb does go dim measure the bias voltage over the emitter resistors ( the white cement blocks), see if it moves by turning the trimmers. When it does dial them in at half of the bias voltage, so around 10 mV max.
Then you can take it of DBT and dial them in to required 18 mV.
Be sure to use the correct setting on the DMM!
Oh, and watch for increase in temperature or smoke the first few minutes mains voltage!!
Always be watchful!
