Each individual channel? No. I always listen to both simultaneously.
The full range response of the smallish 1+1s is insufficient for good first octave response at desired output levels due to diaphragm excursion limits. Most importantly, one must carefully blend the output of the mains and subs for the most linear combined output.
That's where the alchemy comes into play.![]()
Each speaker interacts with the room differently so each needs to be treated as a individual. Since you are adding a mono sub then you could look to it as a monaural unit.
Also as I have reported before, working for a McIntosh dealer when a client challenges you with a problem they would take on your problem as their own and help you satisfy the client.
This is or at least was a BIG deal.
So even though they too had only thought of the MQ104 as a device to correct bass issues when I was challenged with a lower mid issue by a client they stepped up, that is Gow, Russell, and Coderman, to help this sophomore audio guy, solve a 1.5 dB channel to channel discrepancy, which greatly pleased the client.
I know this challenge opened up a dialog within Mac because Gow kept asking me about my room voicing adventures and a year or so latter the MQ107 was released giving us more options.
So yes each speaker individually is important if you WANT to really know. It is stereo isn't it.......imaging stability does matter.
