<<snip>>Nice Kenwoods.
I always liked that TT, something special and synergistic about the styling and build.
Well since the OP started this thread to ask questions about getting realistic bass<<snip>>
Nice Kenwoods.
Raising the speakers off the floor may result in some penalty to LF response. An MQ102 might be a good idea here.
The reason they're only raised 9", still relatively close to the front wall, not toed in, and this model has the woofer very close to the bottom of the cabinet.
The way the MQ manuals are written, it suggests that anything other than the speakers placed on the floor in corners will result is less than flat response to 20 Hz. Not being in corners plus elevated would drop LF response by several dB compared to being in corners, on the floor.
MQ101 is pricey but the basic MQ102, at around $100, is very small for the improvement it's likely to bring.
My 2 cents.
These are bookshelf speakers, and were never meant to reach 20hz, they're fine just as they are no matter what you've read lol. As for corner loading, ya not gonna happen, that's ridiculous, any "manual" that recommends that for these speakers needs a trip to the circular filing cabinet.
I think you're misunderstanding. The whole purpose of the MQ is to allow the system to achieve the same response as though the speakers were placed in corners in a variety of positions without the need for the speakers to actually be placed in corners.
Go ahead and EQ away to your hearts content, I'm not going to be a convert, been there done that.
Convert to what? We're talking a simple device with separate L/R 20 HZ controls, each with 5 different curves. Do you think the man who designed your speakers doesn't know what he's talking about? This is discussed in depth on his web page.
If you want to add devices to your setup because you feel it's somehow lacking that's your choice, my system sounds exactly the way I want it.
Well since you've never tried it, you're not exactly in the position to say whether there would be an improvement or not- would you?
At no time was a slur being cast upon your setup and I even complimented your Kenwood electronics. Your militaristic & defensive attitude in response nothing more than suggestion intended to be genuinely constructive and helpful - is uncalled for.Sorry I even bothered.
Not McIntosh speakers - different story. They look just like Mc speakers and we're in the McIntosh forum.![]()
This is kind of circling back around though, you can EQ or compensate pretty much any speaker to produce flat sound lower than the spec (except maybe some of the Klipsch folded horns where the horn isn't long enough). The problem is that you will quite possibly be asking the woofer for more excursion than it is designed to produce, which would make it impossible for the speaker to be flat at any SPLs above a whisper.
The second concern will be power required. I know that my XRT 20s were designed with the excursion and power handling to be able to be EQd flat to 20 at reasonably high SPLs, ... but the amount of power necessary to produce 20hz at 90dBA is massive, and I'm not interested in setting up a system where I can only use a 500wpc setup.
No offense to anyone (and we're running a 4645B JBL with a 3000w Crown and DSP for a sub so we do know how effortless bass sounds) but the man likes how it sounds, ... you can't do better than that.
Cerwin-Vega? Now we need to get back to the quality vs quantity discussion again, ... one-note-bass speakers are not of my liking.
If you haven't heard the Tribe Towers maybe you should reserve judgement and stop it right there. Your preconceived notions about smaller woofers may be in jeopardy. Better to remain quiet and be thought a fool, than to open your mouth and remove all doubt.
