I restored a Sansui AU-717 last year for another AK'r and was very impressed with the sound quality of the finished unit. I documented this restoration in the thread below:
In April of last year I obtained an AU-919 from a different fellow AK'r for restoration. I left the AU-919 in Florida as we summer in Michigan and there was no sense starting the restoration as I knew, based on my experience with the AU-717 it would be an involved process.
The AU-919 I received is remarkably clean, probably one of the cleanest units of any type I have serviced. All of the original Sansui output transistors are present which is great, hoping they are intact which will be the first thing I will determine. The AU-919 powers up but does not come out of protection. I have read a lot of threads on the restoration of the AU-919 and will plan my approach based on a summation of what I have read. One suggestion that makes sense is to replace the original Sansui NMC1012/NMA1012 output transistors and install sacrificial MJ21193G/MJ21194G transistors. That idea seens sensible....
I purchased a restoration kit from Peace-Love and Music as a parts base for my reatoration. I will probably re-stuff the four oval main filter caps as the kit contains the parts and some of the videos available are very helpful.
I welcome any and all suggestions as I begin my AU-919 project.
Buldging capacitors?
Some capacitor corrision visible above.....
Sansui AU-717 Restoration Experience
I received a Sansui AU-717 from a person I have done some work for in the past. He requested if I would try and restore it and I said that I would. My initial testing of the unit showed that it came out of protection ok but that nether power amplifier worked and that only the left pre-amp...
audiokarma.org
