Looking goodI have completed the restoration of the 2385 Driver board. First, my thanks to Sui-Yogi and JimEGR for the chopstix and Acetone 20 minute soak recommendations. I applied this technique to the last section of the board and as suggested almost all of the significant glue deposits came right off! I wish I had known this technique back when I was servicing the AU-717, it would have saved me many hours of work.
Aside from C39-C42 not being Black Flags I also observed that C51 and C52 were no longer .47uF but were now 1 uF units so I replaced them with 1 uF film caps. I also replaced two resistors that were affected by the glue, they measured at the proper value but I replaced them as they were pretty heavily affected by the glue.
Here is a picture of the finished board:
On other restoration threads I read the driver transistors were not removed and re-seated. I am thinking I will replace the mica/paste with silpads as the silicine grease I saw on the main heat sink was kind of dry.
Thoughts?
Some of the no name silicone generics from the bay or big A seem to be pretty flimsy and it seems like a sharp burr or the sharp corner of a TO-220 device could punch through them easily.
