After taking some time away to ponder the protection situation I thought about my previous post regarding Pin #20 on the protection board. I realized that the meter would indicate a DC voltage event which was probably the wrong approach. I then hooked up my ocilloscope to Pin#20 on the protection board with the negative lead to chassis gnd. The scope was picking up all sorts of extraneous noise, probably because of the long ground connection.
I set the probe to 10X and played some music through the AU-919. As before, when I reached a certain volume level it went into protection and I did not see anything on the scope, though through the noise I probably missed something I am sure. I tried a few more times without success in discerning any event on the scope and then set the probe to 1X. I then advanced the volume and.......... no protection triggered
. I unplugged the probe from the scope but left it connected to the AU-919 to see if being connected to the scope affected things in any way and low and behold, no protection triggered. I then disconnected the probe completely and...............no protection triggered.
Interesting set of events, I thought that perhaps there was a thermal efect as the AU-919 was on for a while and power-cycled many times during the test. I let it play for about an hour and then turned it off and made dinner for us. I just went out to the garage at 8pm and powered the AU-919 back up and turned up the volume and.... no protection, it did flutter once at high volume but after that it played fine.
So now I think I have a thermal issue somewhere in the protection board or the right channel. I will leave the unit off over night and then see how it behaves in the morning. If it goes into protection I will leave it playing at a moderate volume level to warm up thoroughly and then try turning the volume up to see if protection is tripped or not to confirm the issue is thermal. Then all I have to do is see what component is the culprit.........
. I unplugged the probe from the scope but left it connected to the AU-919 to see if being connected to the scope affected things in any way and low and behold, no protection triggered. I then disconnected the probe completely and...............no protection triggered.Interesting set of events, I thought that perhaps there was a thermal efect as the AU-919 was on for a while and power-cycled many times during the test. I let it play for about an hour and then turned it off and made dinner for us. I just went out to the garage at 8pm and powered the AU-919 back up and turned up the volume and.... no protection, it did flutter once at high volume but after that it played fine.
