Note sure if this article has been linked here before.
I am including useful specs from the article.
If you are interested in reading, the review starts on page 58.
https://worldradiohistory.com/Archive-A ... 976-06.pdf
Key bits of info for future reference via google/forum search.
Wow and Flutter: Better than 0.05% w rms.
Rumble: Better than -65 dB DIN.
Tone Arm: Tubular aluminum. Length:
Pivot to stylus, 216.2 mm (8.51 in.)
From the article linked above:
Wow and flutter were measured separately, with the former measuring 0.04%-this resulting from measurement of frequencies below 6 Hz-and flutter-frequencies between 6 and 250 Hz-at 0.03%, and a total over the range from 0 -to -250 Hz measuring 0.05%. Range of speed control on Model 980 was measured by reproducing a 1000 -Hz record and feeding the output to a counter, with the range extending from 967 Hz to 1031 Hz, or just slightly over ±3%.
Model 960, with no means of varying speed, reproduced the 1000 -Hz tone at 1001 Hz.
Rumble, which is probably the most important figure in any report on a turntable, measured 48 dB below the standard level of 3.54 cm/sec at 1000 Hz. Converted to normally reported figures, this means a rumble figure of -66 dB, since rumble measured on a flat system is generally accepted as being 18 -to -20 dB lower than the acoustically perceived level. This is borne out by using the DIN test record No. 45544, "Rumpel-mess-schallplatte," and the specified measuring techniques, which produced a figure of -64 dB.
