BIC Venturi Formula 6 Spec II xover
altecman
Does anyone have any details of the BIC Venturi Formula 6 Spec II xover as I need to restore a pair for a friend.
Hi
what info do you need ?
I have a spare one. I can try to find out the values of the capacitors
if you like.
Hi, sorry to bump an old thread, but was hoping for help.
I was hoping someone could point me in the right direction here. I'd like to replace all the caps, as it seems, they are out.
Not sure, what I need. This is the spec...
Thanks in advance
Well, MF = UF and VNP= Volts Non-Polarized so, you need: .5, 3, 12 and 16 UF caps in 100volts or more. Just make sure you use 100Volts or more. You can buy Daytons at Parts Express, or, if you want top shelf quality, Solens.
Thank you soooo much!!
@turboyam If I were to replace those chokes, which one should I buy?
Inspect the inductors ''chokes'' to see if they show signs of overheating
(possible but un-likely) but don't change them, they are nothing more then a calibrated copper winding.
