Im sorry but I have to disagree with your take on bokeh. A lot of photographers don't consider a picture to have bokeh unless it has some specular highlights in the out of focused background. The pics you have posted as examples are only macros with plain OOF backgrounds.
Look at the photo below as an example of "rough" bokeh. Pics with good bokeh would have more refined patterns/swirls and specular highlights and need to be pleasing to the eye.
Definetion of bokeh from wikipedia.
Coarse bokeh on a photo shot with an 85mm lens and 70mm aperture, which corresponds to f/1.2In photography, bokeh is the blur,[1][2] or the aesthetic quality of the blur,[3][4][5] in out-of-focus areas of an image, or "the way the lens renders out-of-focus points of light."[6] Differences in lens aberrations and aperture shape cause some lens designs to blur the image in a way that is pleasing to the eye, while others produce blurring that is unpleasant or distracting— "good" or "bad" bokeh, respectively.[1] Bokeh occurs for parts of the scene that lie outside the depth of field. Photographers sometimes deliberately use a shallow focus technique to create images with prominent out-of-focus regions.
Bokeh is often most visible around small background highlights, such as specular reflections and light sources, which is why it often associated with such areas.[1] However, bokeh is not limited to highlights, as blur occurs in all out-of-focus regions of the image.
Contents [hide]
