@AdamAnt316: I wasn't aware that Hallicrafters made stereo receivers. My earliest acquaintance with the brand came from a TV that my parents owned. It was an 18" diagonal B&W set with a VHF-only tuner in a blond fine furniture cabinet, and I would guess that it was made in the early-to-mid 1950s. I did more than a few tube tests and replacements on that set to keep it running into its old age.
As far as I know, the
CR-3000 was Hallicrafters' only foray into the world of stereo receivers, though they apparently offered at least one mono audio amplifier during the early hi-fi era in the
A-84 (and its matching A-85 preamp and ST-83 tuner). For 30+ years, all of the receivers they produced were primarily intended to receive shortwave radio signals, which generally don't require much in the way of "fidelity". Most of them, like the
SX-28 and
SX-42, were much too large for the average audio rack not only in terms of size, but also weight, as they generally weigh more than 60lbs.
My first shortwave receiver was a
Hallicrafters S-118 from the early '60s; a step above the entry-level
S-120 (itself the successor to their
S-38 line of basic shortwave radios), it used a mere five tubes plus silicon diodes, though it employed a 6AQ5 for audio output, which isn't too shabby. One odd aspect of it is that it employed a single RCA jack on the back labeled "TUNER OUTPUT AND PHONO INPUT", which normally acts as a line-level output, but switches to being a line-level input when the receiver is switched to 'standby'. Using this, I fed the output of an old
Harman-Kardon A200 AM/FM tuner (one of their first products) into it, and then added a portable CD player to the mix, sort-of making it my first tube audio setup.
Getting back to the CR-3000, it was made for Hallicrafters by Sharp in the waning days of the company's existence, not long before Halli stopped offering consumer products altogether. Its innards appear to be based on the earlier
WR-4000 portable shortwave receiver they offered, as it features the same band coverage and rotating drum dial. Definitely one of the few stereo receivers you'll see with an RF gain control or a BFO function on its front panel. Here are a few more photos:
And for extra added fun, another late-stage Hallicrafters product I own, a model 7002 digital clock radio from the early-mid '70s:
