Broken headshell lead. What can i do?
jeff spicoli
Well-Known Member
I was changing my cartridge and as I was pulling out the wires, one broke. I'm at a loss and so upset. Is this repairable? Can someone point me in the right direction? Its a Sansui SR 929 headshell
It is repairable. If you can solder it could be fixed quickly that way, otherwise there are headshell/cartridge lead kits available for you to just replace the damaged wire.
Thanks....sometimes i need to just step back and relax. I was starting to really freak out. I got to thinking that surely i'm not the only one who has done this
Thanks again. One more quick question.....does it matter which set of leads i get? or are they all basically the same?
Some people prefer exotic wire and say they can hear a difference. It is an area that I haven't experimented with and I've been quite content with the economical ones like those in Balifly's link above.
Don't need nothing fancy. When you find the ones you like I would buy a couple of sets. Just because. :D
