EvilDingo
Hi all,
Started the process of full recap on my SX980
Started with the power supply board. Fired it up. Sounded great!
Last night replaced filter caps with the the E36D 18000uf 75 volt caps
Removed, trimmed, bent and drilled the bar between the two caps ( i also used a wire wheel to clean up the surface...removed a finish on the bar....hope that's not a issue)
Soldered connections to crimp connectors since these caps are screw-in.
Added Bypass caps (non polar)
All went smooth.
Moved on to the protection board and replaced all the caps on that. Did not replace the relay because it looks like there are only 6 posts on the original (did not remove, just observed from under the circuit board) and the new omron that digi sent has 8? Possibly two are not used, or I ordered the wrong one....
Anyway powered it up, relay clicked, everything plays but now I have a Buzz/Hum when volume is down. It is there in all modes, if I pick aux or phono without an input its there, then as I raise the volume it lowers in volume but is still notable. When a mode is selected and I apply input, it plays as it should but still a buz when volume nob is all the way down.
I checked my polarity and solder joints.
From what I read, this can be a sign of bad filter caps.....they are new....did I screw the pooch somehow? ugh....
There is one capacitor I did not have for the filter assembly its the little 1uf/80v that jumps to filter cap assembly ( I only had one for protection assembly between posts 2&3. I used a 1uf/100v for that one).
I am really just getting back into electronics and pretty much forgot everything technical. I solder pretty good and mechanically I get things...but I need to relearn everything regarding troubleshooting.
Any help would be appreciated.
Thanks
View media item 22226View media item 22225View media item 22224
All went smooth.
Thanks
