SweetVintage
Have you tested any of these transistors with a diode checker before replacing? Nothing beats the original transistors.
Pins 20 and 23 will never be right until Pin 20 is right, as both depend on it.
What is the dcv on the cathode of D8, should be about +14vdc.
Q5 collector (input) should have (almost) +24vdc on it. Its output (emitter) voltage also depends on D8's voltage.
Pins 16 and 17 depend on Q5, so it all goes back to D8, which is where to start troubleshooting your voltage regulators.
The older transistors are the ones that, At the Time, were the Correct ones that the engineers that designed it called for. Testing and putting it back in rather than shot gunning hand fulls of subs leaves you less vulnerable to never getting that thing working again. If your sub isn't the correct one for example, and you push forward and say put a couple wrong ones in there you have now complicated the repair process and don't even know it yet. Now with that in mind, I have seen a transistor test good on a diode checker and still fail but typically not the case.No, I havent actually removed the tranistors yet..... I guess I should do that to confirm my assumptions. I don not have diode checker, but I can check with it my MM. Q4 looks like its been replaced by one of the PO's its labeled "TA814 y78" could not find anything about this transistor other than its a Toshiba. The voltages off it were good, I was only going to replace it as preventative. Q5 also looks like its been replaced more recently with a 2n647. this one has no voltage on pins 16 and 17. Q1 looks original but no voltage on pins 20 through 23. - see my pin readings below from earlier in the thread.
I am a new to vintage stereo repair, although enjoying it greatly. Its like a puzzle. I would love to hear why the older transistors are better. Thanks.
I actually see a typo, I meant D8, -13.8vdc is correct for the anode of D9, it is the reference for the negative regulators.You nailed Merlynski! Ive got 13.5 on the anode but nothing on the cathode. I actually ordered a few Zener 1N5243B's to replace as a preventative. My transistors and diodes should be here Friday. I'll start with D9! If thats all that is bad. What is your opinion on replacing the transistors as preventative. It has been mentioned that the original are the best. Being a rookie, I am not sure what to do. Leaning towards replacement. Although I understand that mindset of "original".
Shorted just like I expected. Make sure you replace all the related transistors at the same time, as it is usually a cascaded failure (Q1, Q2, Q5, Q6) and they may be weakened and will fail soon.
btw, that diode test in the picture looks good to me. Conducting voltage at .698V it is in the ballpark. unless I'm missing something here.So this is what I get with the - on the cathode.
I get OL when I have + on the cathode.
This means its a good diode....right? Or is it reverse bias? Sorry, still learning....
View attachment 1880380 .
Original components sometimes age very poorly, and 'replace on sight' is the way to deal with them.Although I understand that mindset of "original".
Yes I agree 300%. I have visited that list a number of times. My point is testing prior to replacement, too many subs in a shotgun approach has its dis-advantages.Original components sometimes age very poorly, and 'replace on sight' is the way to deal with them.
Top Ten Worst Transistors - noisy, failure-prone, whatever... and replacements
I quite agree, the shotgun technique, except under specific circumstances, is not a good repair method.Yes I agree 300%. I have visited that list a number of times. My point is testing prior to replacement, too many subs in a shotgun approach has its dis-advantages.
Good price, $72 on Amazon. I have one of the cheap china ones from the 'bay. You will find it very useful.What do you think about one of these for a noob?
https://www.digikey.com/product-detail/en/peak-electronic-design-limited/DCA55/2013-1002-ND/9687218
