C-80 setup
Bulus54
just purchased C-80 pre amp ,I have two Carver A-220 amps and four new Tannoy xt8 f . Not sure on the correct hookup with the two sets of pre- outs ,one normal and the invert . Please Help !
Welcome to AK..
1.Are the two Carver amplifiers " common ground " ?
2. What impedance are the Tannoy's ?
Running the Carvers in mono the Tannoys would need to be wired in series.
Running the Carvers in stereo. One normal and one inverted to each amplifier. ie. L -- normal , R--inverted to one Carver and L-- inverted , R--normal to the other Carver. On the speakers which ever channel is inverted would need the speaker connection reversed + to - . and - to +.
If running each Carver in stereo.. Make damn sure the switch on the rear panel of the amplifiers is in stereo position.
It brings a big smile to my face, the Tannoys sound so damn good, they were worth the money I have old set that I wanted to use for a different part of my house so I did the new ones for the this setup
Well ,I thought everything was fine until I tried my balance control ,left side is out ,I tried cables even thought maybe one of my amps were bad so I think I need a Yamaha repair facility. Any recommendations ?
