is the C-80 any good?
tygr
Audiophoole
Is the C-80 pre any good in combination with the M-80? I know they were made for each other but how is the sound compared to other pre-amps with the M-80 (which should be here tomorrow, BTW).
Thanks.
Yamaha preamps are pretty neutral, so to that extent, assuming everything is working properly, there should not really be a huge difference in sound between a C-80 and other Yamaha preamps.
I don't have an M-80, but using my C-80 with each of my 4 other Yamaha amps has given me nothing but amazing results.
Also, consider that the C-80 has inverted preouts. I use mine to bridge two of my P2201 amps for ~700wpc, when each one in stereo is only 230wpc. You can also make use of the inverted pre-outs even when you only have one amp, by running one channel out of phase:
IMO it's things like this that give the C-80 an advantage over other Yamaha preamps, rather than differences in the sound of the preamp itself. I have a mint condition Yamaha C-4 that I obtained earlier this year. I did considerable back and forth testing between it and my C-80 and the end result was that I honestly couldn't tell a difference when powering my amps (I did not use the inverted preouts for the comparison, but had it wired normally). Because of that, I'm continuing to use the C-80 as my main preamp. Though if the C-4 had inverted preouts I'd almost certainly be using that instead because it looks way cooler. C-80 is kinda ugly IMO :)
