I have just brought home a C2300 for a listen and to compare to my C-46.
Up front, the 2300 just blows away the C2200. Gone is the slightly lean upper mids/lower treble with little bass impact of the c2200.
This has been replaced with a top to bottom coherence and musicality which is enlightening and to me at the moment, just a little entoxicating.
I have only listened to 3 LP's so far, however SMOG sounded sublime, the Guttertwins sounded dark and mesmirising and the 1st Dire Straits Lp sounds as fresh as when I first bought it 29 years ago.
BASS & TREBLE CONTROLS - WOW!!!.
You can change the bass and treble on the fly from your remote sitting on your fat ass!!. Now how good is that.
The best thing the bass and especially the treble adjustment (up and down by 12db) works an absolute treat. Did I tell you you can adjust from the remote!!. Seriously this enables you to get exactly what sound you prefer from your listening position
Well done McIntosh!!!.
Why don't Mac have this feature on ALL their pre amps??? - god knows a lot or recordings need some subtle help. If you are that way inclined - don't use it.
If it can be put into a 6k pre, it can be put into the 2 pre's above it with a sw change surely ??
I have not used the MM or MC inputs, just my Pass Xono reference phono into the line inputs, so can't comment but not expecting a lot.
Bad point - Why does the remote light up BLUE when you touch a button. Reminds me of a bad LSD flashback.
anyway, back top the music. I would be interested in other owners views of the C2300, as for me, so far it has exceeded what I was expecting.
I'll give a more detailed comparo after a week of use.
cheers
