The finished prototype
OK….
The idea was to add the extra bit of lever to save the switch mechanism.
and I LOOKED for a used one with no results..
So took a switch out of a scrap AU-717..
Cut the shaft off.
Used the mounting bits on the face of the shaft to be the splint.
Laid the new shaft against the old one so the final length would be CLOSE.
Looked at the front sub panel to see how far the first screw would have to be
without hitting the sub panel and drilled 1st hole for 4/40 tap.
Cut new shaft a TAD long so I could file to fit ( if the cut wasn't square ).
Drilled a 2nd hole in the new shaft tip for 4/40 tap.
Eyeball, file , measure, file..
Made a splint of some soft copper from an old AC plug.
Nailed it on the first attempt.. fit everything together checked function
Works nice…. Now used the front panel bits to make the final splint..
Transferred the hole marks, drill 4/40 clearance, dry fit looks good.
Clean it all up, use loc tite RED as a thread lock AND a glue..
Let it dry.. final filing ( take most of the head off the 4/40 button heads and extra thread off the back, hand file the edges, a little black sharpie.. and BADA BOOM a switch extension ! total cost NADA. Time about 2 hrs.
Now the OH BY THE WAYS.. the sub panel has clearance for about 2 switch levers so I MIGHT have to open that up a few thou. and I'm not sure what mods ( if any ) for the thicker shaft to fit in the bezel…
So there you you have it…..
