First....one should not believe all the marketing hype they read. Even Yamaha's. Next, as you point to these 'power curves' for the MX amps, and most of us do not have access to same, how about making a scan of the ones for the MX-1000, 2000 & 10000 and posting them in this thread so we can see what you are talking about? It would be most educational, I am sure. And, last, as Anders has stated, the MX-10000 has design elements in it that appear to be parts from at least two other Yamaha amp designs, the B-2x and HCA. It is unique in this. The fact that the MX-10000 contains the HCA bias scheme does not negate the fact that it also contains the Class A driver circuitry from the earlier B-2x.The class A operation is acheived with Yamaha's HCA design which was subsequently used in their later MX series amps, this is what the Yamaha releases says, if you go my the Japanese MX-10000 brochure, the power curve is the same as in MX amps. Now unless B-2x was HCA design, I don't see any co-relation here.
Mark B - Intersting that you weighed a B-2 and it weighs 5 lbs 3 oz less than the manuals (both OM & SM) state. And that the B-2x weighs 5 lbs more. Will be interesting to read what you get when you weigh the MX-2000.
