My Empire 598 is the first version having 3 speeds. Yours looks like one of the more modern 2 speed models (ii or iii?). Although, I’m not ruling out the possibility that the AC motor might have been swapped at some point.Photo of mine:
Looks more functional than hauling out a level from the toolbox every time.Maybe put a bubble level on the platter to be sure that it is level. I like using a round bubble level and keeping it on the plinth. Just in case I move it around.
Silver to @loudnoises?Borchee,
I think you deserve the audio master’s gold star on this one.
Check a bullseye level by rotating it 180 degrees, the bubble should stay in the same place.![]()
I just leave the level on the table.
I've measured the circular ones against my digital Hammerhead level. They are very accurate.
Same here, I level mine near the center with the mats off. A tiny bullseye level is good for the headshell as well.the platter too!
Plenty of old platters, frames and mats are stepped or tapered to accommodate 7" and 10" with a raised lip. No part of my 1219 platter mat, or frame is actually level save the center disc of the platter!
I only pointed that out because it seems whoever worked on it may not have been very carefulI agree the brass screw suspending the motor look a little beaten but,
as @gadget73 stated, they won't be metricin my area of Virginia I haven’t found any 5m brass screws to replace them yet.
I always clean pulleys with a red scotch pad while the motor is running. You'll need to figure out a way to beep debris from falling into the bearing. Maybe remove the motor and turn it on its side while cleaning the pulleyThe spindle has been cleaned with rubbing alcohol several times and is quite smooth to the touch. The darkness you see is some kind of stain. I could try cleaning with something more abrasive but, I didn’t want to hurt the smooth finish. If it is rubber remnants on the spindle I could try something like Goof-off.
I believe the strobe will work with a incandescent bulb.I’ll try the strobe on the platter under a florescent bulb to rule out my phone app being off speed.
Incandescent will work but the strobe line is rather faint, but it is there, can use it. The cool heat time is slow but consistent and follows the ac cycle. It works, used it many times with a strobe disc.I'm not sure about using an incandescent bulb, usually it's a neon bulb. An incandescent will flicker, but I think that the slow filament cool/heat time is too slow for 60Hz.
Cheap led desk lamp type things too.Neon or fluorescent.
What's the string attached to? Why not just sit the plastic level on the platter?Do not use a bubble level as they are very inaccurate and not good enough for a turntable.
Get a "String Level" at the hardware store. Less than 4$ and they are Highly Accurate!
Perfect for turntables, We even precision calibrate them to a "Reference" level by filing down the legs to make them super accurate.
Glad you got your table sorted out. It's frustrating when you have to assemble someone else's repair.
Last item, We use a heavy Marble or Granite cutting board placed under the table along with four nice 4" Vibration "Pucks" for a Big sonic upgrade.
Yes, It just sits on the platter.What's the string attached to? Why not just sit the plastic level on the platter?
If you ever want to calibrate a level, just put it on a surface and note the bubble position. Turn it 180 and check again. An accurate level will put the bubble in the same spot. If its off, shave down whatever side is high or shim the side that is low until its consistent.
as for accuracy though, you really need a machinist's level. They will give slope in thousandths of an inch per foot. Also ideal if you want to drive yourself absolutely insane with a level. Unless your flooring is a concrete pad directly on the ground, chances are you will flex the floor enough just moving around to throw one of those for a loop.
