If this is the case, how do I correct for this?Sure looks to me like the belt is not riding i the correct spot on the capstan- like it should be in the "spool" shape.
Thanks for the info on the VFD controller. I agree fixing the mechanical issue would be best. Just to clarify, the platter is chronically turning too fast vs. too slow.My next turntable will be an empire. From what I understand, these AC motor are synchronous to the line frequency not the line voltage. As such, you will need a VFD (variable frequency drive) controller. However, your platter is turning slower than needed, there must be a mechanical issue that needs to be sorted.
I’ll try adjusting the knob. I’m located in the US 117 volts 60 hertz.I've worked on lots of Empires...
Your adjustment knob looks like it's tightened too far down.
This causes the motor shaft to "Tilt" towards the platter.... That is No good.
The motor shaft needs to be mostly Parallel to the Platters Drive surface.
Tilting towards the platter causes the belt to "Ride" high and jump up over the top.
Tilting away from the platter causes the belt to "Ride" lower.
Loosen the adjustment knob until the belt rides on the middle of the motor "Crown".
Last item, You say too fast? If it's a lot too fast, Have you confirmed if it's a 50 or 60 Hertz motor and it matches your supply voltage and frequency?
I didn't see where your located.
Hope that helps.
from your photos, the spindle does not look clean
and yes, that thumb-screw is way too tight,
by the looks of the slotted screws that suspend the motor, someone was not very careful with the screwdriver
the 598 has a strobe on the platter, use that instead of your phone
I agree the brass screw suspending the motor look a little beaten but, in my area of Virginia I haven’t found any 5m brass screws to replace them yet. The spindle has been cleaned with rubbing alcohol several times and is quite smooth to the touch. The darkness you see is some kind of stain. I could try cleaning with something more abrasive but, I didn’t want to hurt the smooth finish. If it is rubber remnants on the spindle I could try something like Goof-off.from your photos, the spindle does not look clean
That spacer goes between the motor and the mounts, if they're not in then that's why the motor is riding so high.I found one of these floating around inside the plinth after I cleaned it out. It sort of looks like a spacer. Might this threaded spacer have gone on the two stationary slotted screws between underside of the motor mounting bracket and the motor? I could see how that might make the motor sit slightly lower.
I’m at a disadvantage since, I never saw how it was originally configured.
Does this fitting look like anything you folks have seen before.
Thoughts?
probably not 5mm, I'd expect this to be US machine screws, probably #8 or #10.I haven’t found any 5m brass screws
Borchee,Comparing your photo to others in www, I'd say the platter is a bit high (it doesn't seem to be able to get lower without touching the motor "bracket" though?) and tilted to the right (perhaps it's just the perspective?).
If this is the same as yours (OK, I see the pulley is different) your motor (and herewith the pulley) is to high as well.
View attachment 3837221View attachment 3837222
View attachment 3837241View attachment 3837254
I lowered the platter as far as I could adjust it without scraping the motor mount. I then slowly raised it until the belt wasn’t touching the platter and leveled it 360 degrees all around the platter. It’s now in spec with the user manual, 3/16” from the top deck.![]()
You know, the platter looks like it's not level with the turntable's metal chassis top. The plinth.
I'm not sure if this is normal.
Picture stolen.
Maybe put a bubble level on the platter to be sure that it is level. I like using a round bubble level and keeping it on the plinth. Just in case I move it around.The table it’s sitting on was built of 2 1/2” MDF. It’s super stable and has adjustable legs so it super level.
