JoeESP9
ESL's & tubes since 83
I really want to hear a transformer coupled preamp![]()
Find somewhere to listen to one of these.
Shootout Test | Eleven Passive Preamps with Transformers (remusic.it)
And what was the reason? Can you share?
looks like there are different discussions - using transformers coupled to input or output and transformers for passive attenuation control.
OTL tube amplifiers need more output tubes to get the same output of an amplifier with OPTs. Maybe it was a chassis size thing? The OTL amplifiers I've seen are larger than amplifiers with transformers putting out around the same wattage.mostly that transformers with good bandwidth are expensive, and its much easier to get the same kind of results out of direct or even cap coupling. Transistor ones are considerably smaller and less spendy than tube ones but they're still not as small as even a 1960s capacitor. Direct coupling is the better mousetrap if you can get away with it. No phase shifts and no problems introduced by component degradation.
The other problem, especially when dealing with inverter transformers, is the phase shifts make it difficult to do global feedback. A typical active device will give 0 or 180 for a shift. A transformer does +90 and -90 when used as a splitter, so the phase at the speaker is 90 off from whatever the input is. Can't put that in a global loop and have any kind of useful stability.
If I understand correctly, one of the main benefits of a well thought out output coupling strategy is the protection of the speakers from bouts of unwanted and potentially damaging DC. Big caps and transformers make a direct barrier to the DC. In a direct coupled design, you really need a speaker protection circuit that will shut things down if DC rises above a certain threshold. Probably an oversimplification, but that's about the limit of my understanding of output coupling.
OTL was more of a later development. Need a bunch of tubes in parallel to make the effective working load lower. If one pair wants 6k, parallel makes it 3k, etc. Stack as needed until you can drive 8 ohms. Usually it will be a bunch of triodes wired as a cathode follower so it doesn't take dozens to get the job done.
It would be something reasonable enough to DIY, you'd just need appropriate tubes.
Fair enough point. Mostly I was thinking of the fact that all the parts can be had. No need to seek out some special transformer that hasn't been produced in half a century or more. Power transformers are way easier to source or have made than high quality audio transformers. Finding hen's teeth parts to try and copy some amazing but old design is annoying IMO. Also a big part of why I don't enjoy messing with solid state gear. Ironic as it sounds, parts for transistor amps tend to be more difficult to get than tube stuff. It goes obsolete and out of production about every few years, but tubes that were designed 80 years ago are still available.
I want to hear one. I am fascinated by it, as much as I am fascinated by the sound of different amplifier topologies.
Your pictures didn't load.
