Capacitor Glue
MX117.MC7150
Listener
Recapping an amp that has thru-hole mounted caps. Unfortunately, spacing on the new caps is different, so need to glue them in place on the PCB. What is a good glue to use? Thanks.
You don't need to glue them in place unless the size difference is extreme, the glue originally was there for holding the larger parts in place during wave soldering.
i never use glue it doesn't need it ..in fact i don't like having to scrape the old stuff off it can go conductive
Glue is usually used on capacitors to keep them from breaking contact with the board during times where there will be vibrations. Soldering, shipment, and field electronics can use glue. If it will be sitting in one spot on a stand and not going through extreme vibrations, leave the glue off to avoid future problems.
