they're not really polarized exactly, but usually the neutral is the wire that carries straight through and the hot is the one going to the wiper. Electrically it works either way, but being "correct" will depend which way the cord is plugged into the wall. Possible someone replaced the socket. I'd probably consider changing the cord to a polarized one. Maybe even consider a grounded cord, and ground the case of the variac just as a bit of insurance in the event something goes bad with it.
I'd build a cover for that thing. Its connected to the wall, very easy to get a case of the zappies from it. It will get warm when used with a high current load so just keep that in mind if you do build a case. My old SeCo one uses perforated sheet metal.
