rbphoto
Member
If both LPs have this distortion, it may be in the master. Can you get this similar distortion with any other albums from another artist?
It absolutely may be, part of the challenge here is that I’m not experienced enough with vinyl playback to know what audible artifact is caused by what fault, be it setup, equipment condition, pressing, mastering. I’m learning quickly though!
So when I describe the clipping noise as IGD, I could well be wrong - my understanding is that it usually relates to intermodulation distortion in high frequency caused by the stylus not able to track properly at the lower rotational speed towards the runout, and that’s not the same as an amplitude-related clipping which is what I hear towards the runouts on Endtroducing, which says to me it may have been cut into the lacquer somehow. And that just baffles me. Abbey road?! Seriously? I know there are other possibilities, I want it to be the pressing plant or the deck or me. FWIW the rest of the record sounds fantastic, the consensus on discogs is this is now the definitive cut of this release.
The artifacts I’m hearing on other discs I now realise are probably the result of off-centre pressing, namely a background tearing sound every revolution as the tonearm tries to track the eccentricity. I simply didn’t know to look for that, now I’m seeing it on at least half the titles I’ve bought, to some degree. I don’t know if some arm/cartridge combos make this more or less audible, but I’m sure they do.
Then there’s the pumping/rumble, which is probably there on every second new record to some degree.
So I think the conclusion is the deck is set up as best it can be, and everything else is a product of inherent or introduced issues in the media or environmental factors.
Coming from a machining mindset this is all super fascinating, it’s like trying to hold really tight tolerances on a complex part that is cast, so there’s inherent stresses in it before you even touch it, and then there is tool wear , clamping distortion and thermal expansion to compensate for… I watched Michael Fremer’s tour of Acoustic Precision last night, what a trip. I couldn’t help but laugh at the idea of using these exquisitely engineered precision instruments to extract musical pleasure from your average contemporary commercial vinyl release.
