lorne
Sonic Lizard
Hi Redboy: In recent years I must have made no less than 50 pairs of CAT-5 interconnects using all sorts of RCA connectors. I also obtained some CAT-6 but I have not constructed anything from the stock as yet. Most of my wire I obtained very cheaply as used LAN cable.
The stuff to get if possible is CAT-5 Plenum because it has a Teflon insulation. But any CAT cable is cool because it is good copper, and most CAT-5 is solid strand. I HAVE seen it in multi strand. In fact I have some. There maybe some naysayers that say this is NOT CAT-5, but it says so on the sheathing.
As for the sound: great. I've been very, very pleased.
The downside: having a complicated assortment of components means a lot of wires running all hither and thither. Keeping CAT-5 twisted pair interconnects dressed and untangled is a nightmare. (In addition, they can be fragile and I might suggest filling the RCA plug-end with epoxy.) So as a result, I have been replacing most of my interconnects with sheilded microphone wire, and other interesting stuff I dig up at a shop supplying some of Sendai's telecommunications industry.
But I have to say, a simple CAT-5 twisted pair straight up, no sheath or cover makes an excellent performer.
Don't cut up your cable!! With the ends on that stuff is danged expensive - they'll cut you whatever you want at Lowes or Home Despot. The "plain" is around .18 per foot, the "Plenum Grade" (already teflon covered) is about $1 more per foot. For $3 and change, you can get 3' of Plenum Grade which will yield 4 interconnects 3' long.
