No, but it will reduce (eliminate) induced 60-Hz hum (buzz) in line-level applications. Try it and see."Twisted pairs will not reduce noise in unbalanced circuits"
No cable will reduce noise unless it is faulty.
These two statements contradict each other. Also could you explain the theory behind the second statement.Twisting an unbalanced cable helps reduce massively the RF suseptibilty of a cable and associated equipment.
The ONLY reason you get away with untwisted unshielded cables is because the output impedance of your source is low enough to prevent truckloads of noise getting in. It is a BAD, BAD practice and has no basis whatsoever in good enginnering practice and certainly does not lead to a silent system.
The low impedance I am referring to is the source primarily. If your source has a low enough output impedance, you can 'get away with' dodgy shielding practices (untwisted interconnects) over a short run before EMI and LF and RF ingress gets out of hand. That being said, it is still a dumb idea. On the amplifier end, many amps in the late 80's and 90's used FET input differential amps in either single or dual complimentary topology and, by their very nature, parasitic oscillations, RF ingress and noise is a problem if your interconnects are badly designed, too long in length, or your source impedance is higher than a few hundred ohms. Bear in mind, amps can be oscillating at supersonic frequencies due to poor interconnects and you won't even know until your tweeters start smoking.If low impedance prevents truckloads of noise from getting in, then what's the problem?
Well, After building them and hooking them up, the overall charcter of clarity is still intact and even with the top end sizzle (which rapidly is gone in a day or two) they sound pretty good. The biggest surprise between the 1st and the 2nd is the bass. The RCA plugs really help to bring the bass to a nice, solid, level. That was a surprise to me, I never really gave much thought to plugs, other than to see how they looked.
Interesting, thanks for sharing.Well, After building them and hooking them up, the overall charcter of clarity is still intact and even with the top end sizzle (which rapidly is gone in a day or two) they sound pretty good. The biggest surprise between the 1st and the 2nd is the bass. The RCA plugs really help to bring the bass to a nice, solid, level. That was a surprise to me, I never really gave much thought to plugs, other than to see how they looked.
I never worry about what I do not know, I figure if it is important enough, I'll figure it out.
First pair, 0.5 ohms
second pair 0.2 ohm
Not a lot of difference, but it is measureable.
Edit - sorry, my meter is a cheapie, kinda like everything else I have, and does not measure capacitance. I got a ohm reading quickly not really thinking about what you were asking.
OK here we go. The two statements in no way contradict themselves. A faulty cable can be shorted or open circuit. If it is shorted it WILL reduce noise in the system significantly. Have you ever noticed the shorting plugs across unused phono and other inputs on quality amps? They are not there to look pretty, they short the inputs to prevent NOISE getting in when unloaded. That noise can be anything from DC-daylight. If the cable is completely open circuit, it can also reduce noise as there is no connection to the hot (centre) input rca. Basically, a cable cannot reduce noise unless it is faulty. That being said, certain configurations of cable can and DO contribute to INCREASING the suseptibility of a system to noise. Again, that noise can be audible (from 20-20kHz) or above, and that is what I will address below.
As for twisting, look inside any decent amplifier and you will find neatly twisted PSU, signal and speaker cables. Why? Not because it looks pretty. Not because it may require 30-50% more cable length, but because it stops dead in its tracks, induced NOISE.
You may or may not remember AM RF breakthrough in the 1970s when the first wide bandwidth amplifiers came along. What caused it you may ask? The speaker leads. Why? Because they were nice parallel aerials and the RF was duly picked up and routed back through the feedback loop, detected by the front end and amplified so you heard a local AM station through your amp. Wow! What solved it? Twisting the speaker cables and reducing the RF ingress by mutual cancellation and self shielding.
Need any more convincing?
The resistance (ohms) is insignificant in interconnects. The capacitance is what most affects sound quality. If you want a capacitance tester you can find cheapies on the internet for around $20.I never worry about what I do not know, I figure if it is important enough, I'll figure it out.
second pair 0.2 ohm
I have a meter with capacitor checker ( with good batteries) and I get a O.L readings when checking a single solid wire in a Cat5, is this normal?
From one end of a the wire to the next. It would be a short, but that's how I thought it is done. No?
