interconnect cables
Obviously the concept of balanced LINE level cabling for interconnecting devices to cancel induced RF noise and hum rejection is widely understood and used. That noise can easily be heard as it is usually 6ohz.
I have read all the claims here about "sizzle" and
"sonic brilliance" etc. as a result of using CAT5 cables, as well as the usual hyperbole about the flash coating on the connectors and BTW, none of the connectors are base metals of gold etc-. They are all electroplated and they connect to copper PCB traces soldered with lead/tin solder just the same as inside that pretty and expensive plated RCA connector.
All the claims have been based on strictly subjective human hearing of various pieces of music. In order for these claims to have any real veracity, calibrated lab grade testing equipment must be used. Otherwise is is just a case of "it sounds good to me".
Proper resistance and capacitance measurements require a calibrated and constant clamp force between the calibrated test leads and test equipment and the cable/device under test. Just holding the probes of a 15.00 RadShack meter against the ends of a connector is not a valid test procedure.
In addition, a calibrated level, automatically swept signal must be passed through the cable under examination and fed into an oscilloscope, audio spectrum analyzer, and DB meter with a calibrated load. If these procedures are not followed then all the claims are just as I said- "it sounds good to me"
This is why folks have gotten browbeaten into such phenomenal silliness as Litz cable.
Stop and think about the GIGO concept. The recording studios use Canare , Mogami or similar star quad mic cable to connect thousand dollar mics to the pre-amps etc.
If O-T-S cable works fine there, what makes anyone think that all this cable hyperbole will improve anything?
It's just the same with speaker cables. The testing labs for 20 years have laughed at Monster cables et al and found that Romex or SO cable works as well or better.
It ain't pretty but are you looking or listening?
