blind bruce
Member
Since CDs are digital and tube amps are analog, why spend extra dollars on a tube amp? If I only play LPs or FM radio, perhaps but what will I gain going from a 200W solid state Sumo Andromeda to a 15W class A tube amp?
You will gain much higher levels of measurable distortion that many find pleasing.
jblnut
Well said twiii. That brings up another question, would a more modern CD player sound any better than my 30 year old Harmon Kardon?
Well put. Just like vinyl, there are good and bad masters.Maybe you shouldn't! You will lose 185 watts, more or less. The question is whether you actually use any of them. Maybe you do, maybe you don't.
Expectation bias can work both ways; a skeptic may confirm his worst fears.
IMO, most CD aversion is caused by compressed or otherwise poorly done mastering, and in the worst cases, there is no 'taming' them via equipment; those are doomed to sound flat and harsh. For the CDs that are mastered well, no special treatment, buffering, or EQ is needed by most people.
Your first phrase (Since CDs are digital and tube amps are analog) is not related to any relevant causation here; it merely confuses the matter. The signal is analog by the time it is amplified.
Spelling and proper grammar are not the issue here!!!!
He has posted a reply that is useful....unlike some......
Question still unanswered is will a more modern CD player be better than my HK model HD7125?
My speakers are very efficient Paradigm K95s with a SW1000 Paradigm 1oooW sub woofer. The listening room is 25X18 feet and carpeted. The dealer of the 15W amp says that it is more than enough power because I have the sub. It will cost me $2500 to find out!
