CF3600LE SET UP
ZR9B
Well-Known Member
CF360LE I am putting this cart on a pansfed aluminum head shell (for now) ....what should the overhang be? I didn't see a specific #for this cart. It's going on a LAB 500 realistic if that makes a difference...... thanks
Yes, it makes a difference. Overhang is a function of the tone-arm so you need to find out the proper overhang for the LAB 500. This will apply to any cartridge.
The important thing is the position of the stylus tip. You can find what you need at vinylengine.com. or you can use an alignment protractor. You should be able to download and print one online.
Just for the record..... even if I have the cartridge all the way forward there still is no overhang....the wall sounds great.
