kahlfin1k
Well-Known Member
"Originally Posted by kahlfin1k View Post
If a distorted signal fried speakers every guitar amp ever would have blown speakers."
Clipping is distortion, but not all distortion is clipping. When the output waveform is different than the input waveform it's distorted. Example: Input waveform is a sine wave, output waveform is a sawtooth wave. An amplifier should only amplify the input not change it. A clipped output waveform has chopped tops and bottoms, so is different than the input, so is distortion.
A guitar input is not distorted. Some guitar amps apply a pre drive circuit that will clip before the power amp or a digital circuit that emulates this sound. In this case the signal reaching the power amp WAS distorted already. However, that design concept came from the desirable sound of power amps clipping. That's why guitar players like tubes. They sound good when they clip. Analog SS does too though. Many guitar amps have no "overdrive" or distortion control or circuit. You basically turn up the gain until it clips and there's your fuzz. Guitar amp speakers are rated for way more power than the amp supplies so that they CAN be driven to clipping without blowing the speaker.
