nailer
audionerd
Too much power to the woofers, plain and simple. If the volume knob wasn't touched, and a larger amp was used, the same thing would have happened. The only effect clipping had was to REDUCE the heating of the woofers very slightly, by directing about 1% of the amp's power to the tweeter, in the form of harmonics.
It can hurt one's brain, for sure: in this case, the 40 Watt amp might be putting out 100 Watts of square waves. BUT... that is not caused by the clipping, it is simply a matter of the volume setting. Using a big amp that didn't produce square waves would also put out 100W under those conditions and also blow the speakers.
Sheesh, after many, many hours of posting here, I should avoid this topic. I have already explained it generally, mathematically, drawn diagrams, given technical references and experimental setup for people to try. But, a new year, and a new crop of folks need to reconsider the "facts" they learned about small amps and speaker damage.
Smaller amps = safer speakers. Loud music = blown speakers.
-k
And now I know the rest of the story. Thanks Quackman, once again you've saved the day!
Ignorance may be bliss, but knowledge is better.
