Colored vinyl?
It's definitely a different color than what I've seen from Quiex II, aka "Super Vinyl" as MFSL referred to it. One other possibility I can think of is styrene, but not many LPs were pressed using it, AFAIK, and the styrene 45s I've seen are generally a more reddish purple than what I'm seeing from this LP.
-Adam
Quiex II and MFSL "Super Vinyl" was not the same according to a thread on steve hoffman forum, but I don't have any personal knowledge.
This Tool picture disc sounds pretty good.
I also have a Deftones Diamond Eyes white vinyl pressing - actually sounds great.
I have had shite sounding discs in the past though - I had heard that these are made out of acetate, rather than what is usually used to press black vinyl records. That could be a load of old bollocks though. But the ones I didnt like usually sounded a bit tinny and had heaps of pops and other surface noise.
Translucent gold: Madcats (debut)
Translucent rich medium blue: ZON (Back Down to Earth)
I have a VERY deep purple Deep Purple. For years I thought it was black, but turning it over once, something caught my eye so I held it up to a light and found out that it was coloured vinyl. Sure sounds like black vinyl, though.....
Well, I don't know about the chemical makeup of either, but both of them definitely look very similar, if not identical, when you shine a light (in this case, a "Coast" LED headlamp similar to this one) through the record. Here's an example of Quiex II vinyl, a promo copy of Neil Young - Trans:
And now here's an example of Super Vinyl, a MFSL copy of Steely Dan - Aja:
Now here's the copy of Lyres - On Fyre I mentioned earlier, looking much different than either one of the above:
And for good measure, here's two views of light shined through a styrene 45, in this case Shocking Blue - Venus b/w Hot Sand:
Well, I don't know about the chemical makeup of either, but both of them definitely look very similar, if not identical, when you shine a light (in this case, a "Coast" LED headlamp similar to this one) through the record. Here's an example of Quiex II vinyl, a copy of Neil Young - Trans:
Thanks for sharing those pics. I will look at some MFSL and I must have some Quiex and see if they are consistent.
I noticed you posted that the colored version did not sound right. I wonder if you had a bad pressing. Mine sounds just fine.
I have quite a few colored vinyl records...
Given the choice I usually prefer the non-colored version, with my only real complaint that a couple of "marbled/mixed color records" sound not as good.
My only real bias is "picture discs," I don't want em.
Ben
I've noticed a bit more surface noise with a couple marbled records I have. The rest of the colored records I own sound fine. One though even after buying two copies sounded bad. That was Pink Floyd's Wish You Were Here album. A friend had a copy also. Same thing, very noisy. It could have been due to too many copies made before swapping out master discs maybe?
I'm sure it was a bad pressing, As I said in an earlier post, it sounded like it was dragged behind a gravel truck. I've had scratched up thrift store records that sounded better. I had it exchanged for a copy on black vinyl and that copy sounds fine.
Those are hit and miss it seems, mine sounds pretty bad (and not just in the picture, but in the sold black areas as well).
chelsea wolfe - abyss, clear blue double album
chelsea wolfe - birth of violence, both were tour merch editions
boris - love/evol - tour merch limited editions
nazz - nazz nazz
