It's not HiFi, but it's an oddball and it's old. It's an Oahu lap steel amp from before 1940, as far as I have found but have never seen a schematic, read anything about it or seen another exactly like it. The 1940 and later models have an octal socket in the chassis for a harness that connects to the field coil speaker, to enable removing the chassis without the speaker (unlike mine). It uses a #80 rectifier, 6C8G dual triode, 6Q7G Duplex diode and 6L6G output tube. SE Class A, all original KenRad tubes and absolutely nothing had been replaced, although the 6C8G and 6Q7G had been swapped and the rectifier didn't work. I suspect these were the reasons it was covered and left in a closet, unused.
I posted a few other photos in the "Let's see them axes" thread here, too. I re-capped it completely (all of the caps were wax and paper/foil), found some #80 rectifiers on ebay and fired it up a couple of nights ago- sounds better than I though it would and has some balls.
