Common, Rare, Odd, & Obscure Amplifier Poker
Another rare one, almost no info on the net. Passed to another AK'er US audio SE EL-84
Within the last couple weeks there was a thread running on a Radio Craftsmen stereo SE amp. I commented that it was likely made long after the R-C name was passed onto another company. Someone else replied they thought US Audio ended up with the name and your amp and that one appear identical except for the faceplate.
Can't find the thread now and not sure why; deleted?
:dunno:
Found it:
http://audiokarma.org/forums/index.php?threads/recapping-radio-craftsmen-sep-amp.785526/
index.php
index.php
index.php
AA, that is a cute liddle amp. The OPT's have a cathode FB winding...:) I came across one 20 years ago. There are( as you know ) a lot of parts crammed under there.
cheers,
Douglas
cheers,
Douglas
Yes indeed. :eek: It still has several of those nasty gray oil capacitors under the chassis (though some have been replaced, notably the output bypass caps), which I have yet to build up the courage to start replacing. It does work to some extent, though I'm not going to use it much until I finally get around to recapping it.
-Adam
My rarest amp is probably this old Stromberg Carlson AR-415. Maybe not super rare but likely to be one of the rarest on this list that is still in daily use. I have it set up as a mono system with a Stromberg-Carlson tuner and a Schiit DAC and it is filling the house with the sound of the local jazz station as I type.
My dear little Bell 2521 mono receiver. Picked it up off eBay years ago not knowing it was a mono unit. I just laughed at myself. It was my first recap. EL84's probably put it at 12 watts. There's an EF86 rectifier.IMAG1389_1.jpg IMAG1388_1.jpg
Last spring I scored a single 604d in that cabinet the Bell is sitting on.
Awesome —that seems pretty much the same chassis, layout, and tube complement as my Radio Craftsmen A-1000. Been looking around and this is one of the few images I've seen. Thanks for posting! It's not fancy, but it sure does sound great :music:
EDIT: Ha! I just saw the other posts on this...I should wait to read the entire thread before posting, I guess.
Like mine, also.
Surprised no one has mentioned the very unusual Stromberg-Carlson ASP-422. The only amp design I've seen, that used the 6DY7 output tube. Basically, a 6DY7 was like two EL84 tubes in one bottle- about 15 watts from a single tube in PP.
I had one of these that I restored here, but can't find a picture from that one- however, here's a picture of one from Tom Bavis' web site:
It's a pretty stout little amp- more power than an ASR-433, by a bit. I think that's probably due to the output transformers being a bit heftier than the '433...
Regards,
Gordon.
