Converted to heat ?? I vaguely remember such claims over the years.. but I think that I was left shaking my head.
If there were any substantial amount of energy there it would melt whatever it was contact with .. and the material would have to deteriorate with the heating cycles. ..
Little energy little heat ok maybe..
I would want to ask Mr. Atkinson why 3m didn't buy the patent ..
Friction is usually what converts mechanical energy into heat ..
If someone could figure out a way to make acoustic vibrations do useful work or create heat it would be worth a mint ..
Around 99 percent- actually probably more on average- of all energy put into a speaker, is already dissipated as heat.
Speaker drivers, on average, are ATROCIOUSLY inefficient devices at turning electricity into sound. A speaker that's 92dB sensitivity at one watt, is exactly ONE PERCENT efficient at converting electrical power into acoustic energy. The rest is converted to heat, in the voice coil and magnet assembly.
A speaker that's 100% efficient, would produce 112dB in all directions (spherical dispersion), at one watt, at one meter distance. Conversely, it takes 112db at one meter distance, to achieve one watt of acoustic power from a source. 92dB @ 1 meter, in turn, would be 10 milliwatts of acoustic power.
By those facts- it's quite obvious that the amount of energy dissipated by a panel as heat, is MINUSCULE. As in milliwatts. But, it WAS audible potential energy, that's no longer audible.
As for audible vibrations doing useful work- ever heard of ultrasonic welding of plastic? That's EXACTLY what's going on there. Vibrations (MUCH- as in orders of magnitude- more powerful than a speaker) heat up a plastic seam, to the point where the plastic edges melt and fuse together. Used in the assembly of LOTS of consumer products. That wall wart that you just plugged into some electronic device? Very likely was ultrasonic welded together, just as one example. This can be done, because the frequencies in use are orders of magnitude higher than audible sound- it's MUCH simpler to make an acoustic device that's close to 99% efficient, of a size that can be used in an industrial process, with wavelengths of that short of a size.
But, in a common speaker- the baffle and diaphragm sizes are SO much smaller than the wavelengths involved- that the acoustic impedance mis-match with the air, means that most of the energy never becomes acoustic pressure- instead, it's wasted as heat, before it even gets out of the speaker cone.
So, rest assured, the cabinet walls are not in any danger of catching on fire. Unless the voice coil of the driver itself blows up and catches on fire, first. And that I have seen personally, both during and after the event.
Regards,
Gordon.
