relaximus
Consoles 'Я' Us
The original cap value is 40uF 25v. So 2 20uF/50v (in parallel) should work, right?... two 20uf's in parallel is only 40uf. if you can't get 50 or more, use 47uf. less than 10% should be tolerable i think.
Dave
Dave
Thanks gogo, I really want to get this console back in shape and intact. The little Maggie, however, is going to be sacrificed for stand-alone duty. A little SE 6bq5 amp should be great fun!... good luck with your restoration! :thmbsp:
Hot glue gun okay for this?... don't be afraid to extend terminal wires and install them to the right side of the under chassis. use glue to make sure they don't come loose, and also use heat shrink.
AA:What is that rectifier there? 5U4GB maybe? If so, you don't want to go any higher than 40uF for the first cap. ...
According to the data sheet, the 5Y3GT typical filter input capacitor should be 20uF.
So then according to the above list shown on the can, the first 2 are filter caps going to the 2 output tubes. The 3rd is is for the rectifier. What would the 4th be for?
- 40uF 400v
- 40uF 400v
- 20uF 400v
- 40uF 25v
And which ones is it safe to increase the capacitance and voltage for?
Dave
And can I safely assume that the caps I've highlighted below are ceramics and won't need to be replaced?
Dave
AA:Actually, those are all electrolytics and NEED to be replaced.
AA:
Oh my, that is depressing. :tears: This is turning out to be something way beyond my capabilities. I don't even know how I get to some of them buried under all those resistors. I really don't think I want to try my first recap on this amp.
Dave
AA:... Get 600 VDC or 630 VDC rated poly film caps.
I thought I would need to use electrolytics to replace the 4 caps in that can, no?While you're under there, you may want to replace the multi can cap. This can sometimes be a little more challenging just to understand the connections, but it's not that hard. Typically I do this with discrete caps and a terminal strip.
Dave
Dave, it's actually easier than you think.
First get a nice thin pencil or small screwdriver tipped soldering iron, say 30 watts. I also have a de-soldering iron, which is a more powerful iron combined with a bulb suction device for removing old solder. Both of mine are from Rat Shack.
Also, get the Rat Shack set of soldering tools, which include a heat sink, and some straight and bent tipped probes/tools for teasing apart crimped leads. Of course you'll also need some resin core solder for reforming your joints.
Make an inventory of all the caps you'll need, and then get them from a reputable on-line seller. I see some .25 and some .02 uF caps , along with some others not visible. Get 600 VDC or 630 VDC rated poly film caps. Some folks like Sprague orange drops, others are more or less picky. Buy more than you need, cause they're cheap, and once you do one amp, the next is a lot easier.
Then once you have everything collected, take a high res picture of the underside of the amp so you'll always have a reference. (schematics are also helpful but not a requirement for a re cap)
Then start with one cap at a time, unsolder one lead, resolder the new cap to the same position, and then carefully thread the old cap out from underneath the other components. This way, you won't forget where anything goes. Rarely do you have to remove other components out of the way. Desolder the other lead of the old cap and solder the other new lead in its place. Newer caps are typically smaller, which helps
Repeat as necessary until finished.
You CAN do this......:thmbsp:
AA:
So I can use poly film caps to replace the electrolytics on the underside of the chassis?
Dave
AA:
Dave
