Wow guys, this is really quite awesome! You have almost built my confidence up enough to tackle this project.
Another question if you please: How best to go about approaching this rat's nest? This is the underside of that 4 section cap can.
Dave
One of the problems is that things are tight underneath that chassis. You have a couple of choices.
You can cut open the can, dig out all the scrap, and stuff the new caps back inside. Alternatively, you can look for a space underneath there to mount a terminal strip and do discrete caps as a replacement. Sometimes it's easier to mount to the side of the chassis. Also, that large (.25uF) caps replacement will undoubtedly be smaller than the OEM part, so you will gain some space there.
I'd do the can last after replacing all the other caps, and firing it up on a variac. Follow the sticky at the top of the Tube forum page.....
