Copying CDs
chiroman
Well-Known Member
Does copying Cds (download to Itunes then to CD-R) affect the quality of sound? I copied a bunch for my car audio and they dont sound as good as the regular CD itself. Just hate to carry my CDs around like that... Any suggestions?
Thanks
did the same thing load allot cd s in lossles format to my computer .burned allot cd s for car .i was very lucky driver :banana:
later i compared burned itunes cds with original on highend system and allot
different sound .
but it s freeware (itunes ) and makes fun
iTunes, absent tweaks, will convert to a lossy format.
While this format is fine for iPods and earbuds, it can sound a tad crappy on your home stereo or with car audio.
If you want an exact audio copy, I use and many AK member use the freeware "Exact Audio Copy."
http://www.exactaudiocopy.de/
Cheers,
Ken
The default setting for ripping CD's to iTunes is 128 kbps. If you don't change it, and then copy that to a CD, it will sound noticeably worse than the original CD.
I changed my iTunes setting to 320 kbps, and in the car it's pretty much indistinguishable from the original. If I play it through my main home system, then I can (slightly) tell it's not quite as good as the CD.
You can also set iTunes to copy the CD as a lossless file, and then it will be the same as the original.
I find that considering that I use my iPod for travel, 320 kbps is a good compromise between perfect sound and a reasonable file size.
Not to nit-pick but the correct term is not to copy discs, but to back them up. :D
Scott
While the RIAA disputes your right to back up your CD, if your lawyer does not advise against it, by all means use EAC in ecc mode. Also look for 'audio' CD blanks. Burn your backup with as slow a speed as your hardware allows. You should end up with as good or better copy for backup of your CD's.
Be sure to microwave your backups should you sell the original.
I make copies of my own CDs for carrying around using a PC running under Linux OS. I use a program called cdrdao (or eventually cdrecord). I use plain CD-Rs (I try to use black rather than silver ones), not the more expensive audio CD-Rs. I use a HP burner and burn at 8x speed. My copies are sonically indistinguishable from my original cds when played on my major setup (denon dcd1500 cdp).
All the best
Audio CD's have scms on them (serial copy management system) Data cd's do not. Audio CD's are meant for stand alone cd recorders. If you are backing them up on a pc Data cd's will work. My personal favorites are Taiyo Yuden. I have never ever had a bad one. Can't say that about any of the others even Verbatim, which is really good and should be considered also.
Steve
Steve
Thanks for the reply, Steve.:D I already knew everything you stated (as I once owned a standalone CD recorder). I was just wondering why drknstrmyknight was recommending audio blanks over data blanks. His statement made no sense to me, as audio CD blanks have an added cost.
Jeff
The only reason the "audio" CDs exist is to use in standalone CD recorders.
They cost more because the extra $ (supposedly) goes to the artist cheated by the record companies.
Use regular computer CD-Rs.
I've always used the Copy CD function in Nero and have never heard any flaw. You can also use CDex or other ripping software and rip your CD to .WAV format and the use yoru burning software to write the CD from the .WAV files. Wav files are huge so you will need to have space on your hard drive and most of the time you will want to lose the files when you are done with them or your hard drive will fill up fast. Another thing to remember, which is not known universally, is that most burned CDs are good for only about 5 years and after that time will start to deteriorate. Keeping them in the dark will help extend their life a bit, but who can do that in the real world.
Admittedly this is not scientific in the sense that it was not tightly controlled, but a few years ago at work we tested 10 or so types of blanks in the 12 cars of our developers. These were written with four different cd writers.
The Fuji and Sony "digital audio" blanks written on an external 24x Plextor at 4x were the only disks that played in all 12 cars. However one Chrysler seemed to 'eat' disks after 10 or so playings... They quit working in his car and every other car. If what you're using works with your equipment, you're home free.
Now I get it! Thanks for the clarification. Sounds fair to me.:thmbsp:
Jeff
Back them up with Exact Audio Copy... Google for the best settings for maximum quality as I don't remember them off the top of my head... and burn them with Burrrn (also free!) at 1x and you will be very happy with the results :)
That's not quite correct. The discs don't have SCMS, the recorders do. The cd audio discs have a little bit of data written on them that tells the cd recorder that it's for use in a standalone deck, otherwise they're identical to regular cdr's. Some of the older Philips cd recorders could be 'hacked' to use regular computer cdr's. They charge more for the cd audio blanks since they collect a royalty on them that's supposed to go to the artists.
Slow speed burning has more to do with playback compatibility compared to the brand of blank used (except for no-name stuff.) The slower you can burn, the more time the laser has over that particular spot on the disc to burn a more precise and deeper data pit.
A pit or no pit equates to the digital Ones and Zeros. Instead of almost nice round easily distinguishable data pits, the faster rotational speeds produce a smeared "teardrop" effect which will cause some decks to incorrectly identify the next space as a One instead of a Zero or just skip and poop out altogether. I have an old Pioneer burner that I keep around that will do 2x which I still use for audio compilations. My newer CD/DVD combos won't go below 4x and I've seen some that won't go below 8x-10x.
That's always been my theory, and I guess I need to hold on to these "vintage" burners that will go to 1x :thmbsp:
My girlfriend listened to a backup I made and asked me why mine sounded so much better than hers do. It was the burn speed, she is using EAC and Burrrn now and can hear the difference, so I know it just isn't my "paranoia."
We spent most of the day "re-backing up" CDs, and barely made a dent in her collection. It does take FOREVER to burn them.
Yeah just double checked, Burrrn on both our machines is set to burn at 1x.
