guiller
Toscaninichus Australis
Slow speed burning has more to do with playback compatibility compared to the brand of blank used (except for no-name stuff.) The slower you can burn, the more time the laser has over that particular spot on the disc to burn a more precise and deeper data pit.
A pit or no pit equates to the digital Ones and Zeros. Instead of almost nice round easily distinguishable data pits, the faster rotational speeds produce a smeared "teardrop" effect which will cause some decks to incorrectly identify the next space as a One instead of a Zero or just skip and poop out altogether. I have an old Pioneer burner that I keep around that will do 2x which I still use for audio compilations. My newer CD/DVD combos won't go below 4x and I've seen some that won't go below 8x-10x.
Perhaps I'm totally wrong on this, but I understand that pits and hills (differences in profile depth) are more a feature of commercially produced CDs. CD-Rs have a chemical layer that is flat in profile and changes color after being hit by the laser of the burner. They simulate the profile of hills and valleys by a sequence of obscure and clear spots on a flat surface, which causes a similar difference in the reflectivity of the laser of the reading machine. This is what I first read when CD-Rs came into the market and an explanation as to why some lasers could read them and some not, owing to a dependece in the light frequency of the reflection coefficient of the material in the CD-R.
All the best
