Edit: Solved, see post #82. If your CR-1020 is stuck in protection, and the FM tuner dial is stuck to the left of center, check TR712 and TR715 on your Power Supply board!
I just recapped my CR-1020 (electrolytic board, power supply / protection board, main amp boards) and now my DBT burns bright and it won't come out of protection. Neither do any lights illuminate at all.
(However, and this is odd, but if I unplug the power supply board from the elecrolytic board, the LEDs turn on and the light bulbs show very dim current, and the DBT while still very bright is slightly less bright.)
I measured O-E on both amp boards, very low, no DC issues.
Since it isn't a shorted output transistor, back to the power supply. I started with the transformer ... and, uh, I don't think this is right.
Between Blue wires into the power supply board, I am measuring about 2.75VAC, manual seems to spec 17.2VAC (hard to read)?
Between either AC (red) to CT (black) into the Electrolytic board, I am measuring about 5.75VAC, manual seems to spec 36.0VAC.
I had a variety of loose connections which I re-soldered, and verified all wires between boards are intact in the correct spots and soldered. All new caps are in correctly. I also replaced TR712 and TR715 on the power supply board with TIP31A. They are in correctly (hard to mess it up thanks to the heat sinks).
I'm a bit flummoxed, it was operational before the re-cap. Would love any thoughts you all may have.
Thanks,
Ryan
Thanks,
Ryan
