Broken wire? Cold solder?
Found a second person with the exact same symptoms as me ... but the thread was never resolved.
Starting to sound like a common issue. But, my 2SD234s are gone (TR712, TR715 replaced with TIP31A) so I don't know if this theory holds water.
Super...All's well that ends well.
This thread is almost a year old...mgl99, You might get more help if you start your own thread. I just started a very similar thread for my CR-1020. What are your voltages at TR702?
LOL, I misread the date!This thread is almost a year old...
Good job & thanks for the info. These old Yammies were design engineered so well that today's problems often result from simple physical/mechanical faults like that. I say simple with humility cuz it seems that way when we finally find them. But can take time to find them. Wish they were sold with a magnifying glass in the box.Just had a very similar issue. Bias and DC as they should be but wouldn't flip the relay.
TR702 had ~19V on E and B and close to zero on C.
Turned out to be bad connection on the connector pins from the Filter Capacitor board AND bad connection to TR712 just like this one, and bad connection at TR702.
The traces on these boards as not to mess with ...
Here you can see the connector pins with degraded solder from mechanical movement and heat.
