Oilmaster
Sonycus Peritum
You are welcome.
I am not sure where you got 10 ohm values from, but my CR-1020 manual circuit diagram shows:
R801/802: 33 ohm (mouser 588-93J33RE)
FR801/802: 22 ohm (mouser 588-93J22RE)
Euh no.... I wouldn't use 10 ohms instead, because that would raise the power rail voltage, perhaps even above the 50V rating of C805/806. In fact, it might even overload the other resistors.
I changed R803/804 from 4.7K to 10K to lower the heat dissipation (keeping things cooler in this overheated region). Those resistors are so-called 'bleed resistors' to discharge the 18,000uF capacitors after the unit is switched off, and by no means they have to be 4.7k. They stay MUCH cooler now. Those are Vishay CPF3 (3W, metal film, mouser 71-CPF310K000FHB14)
edit: there is a 10 ohm resistor (fusible resistor FR803), but that one is not subject of the SB !
