Retrovert
Addicted Member
So again i was in the right place at the right time... actually i am working on my Spendor Preludes thats been recapped some years ago these Alcaps were replaced with Filmcaps of different brands. Since then i never get happy with the Spendors. So now i changed the 10 mF MKT/Monacor which is direkt in line with the Audax tweeter to WIMA MKS and added a 1Ohm resistor. - Sweet sound is back again !
Excellent work in successfully upgrading to your satisfaction using the padding resistor.
An adjustable L-pad might yield further improvements, unlikely at that low impedance, but one never knows. A more suitable balance between the tweeter and other drivers might be achievable. The Audax is a very nice tweeter, and is more efficient, often by as much as 3 to 6 dB, than many of the other drivers with which it is paired. So slightly greater attenuation, without changing the overall impedance, might yield an audible improvement.
If you were local I'd lend you a pair of L-pads for this test, but I don't know what subway stop Germany is. Must be the one behind that secret door in the Times Square station, the one marked "'Beware of the Leopard".
The Monacor MKT and Wima MKS are both polyester, which has somewhat less desirable properties than polypropylene, but which will, nonetheless, still run circles around electrolytics. Polyester was the most affordable choice at that size in the 1980s, but better options, at far lower cost than in those days, now exist. You might try tinkering with one speaker, replacing the capacitors with polypropylene, and doing an A/B comparison using a mono signal. Bypassed (see below) would be even better.
When we have one watch we're always sure what time it is, with two we're never sure. Not sayin', just sayin'.
Many thanks to all of You who wrote in this thread, especially Retrovert.
You're welcome!
Oh, and i learned interesting things: Bypass Filmcaps in Xover is like lipstick on a pigs mouth
That was actually in the context of using film bypass capacitors to attempt to compensate for the poor performance of electrolytics in filters, including crossovers . See Number 28 where I wrote:
I have previously explained in this thread, and elsewhere, why electrolytics are unsuitable for filters. Any such use creates a degraded filter and it is impossible to compensate for that. Bypassing is one approach, but that's lipstick on the pig.
That's a little hyperbole, as it would, of course, improve the performance, but not enough to equal the results from polypropylene or other film.
I am, to clarify, a firm believer in bypassing, and in constructing larger capacitors from smaller values. See, for example:
Great work on successfully completing your upgrades!
