A history of mods
The RF-83 is a damn good speaker right out of the box but being the person I am nothing stays 'stock'. The first mod I did when I got these was to replace the internal wiring (the Monster cable looking stock wires were all oxidized around the terminals and down the wire a few inches) which made a nice improvement, especially in the bass.
The next mod was to block one of the three ports which took out some of the boom (these speakers go down to 29Hz) that was from room modes. After I did that the tweeter was too hot so I put a 5-ohm resistor in place of the buss-strap between the woofer and tweeter binding posts.
A little later I put adhesive damping pad material in the back-side of the horn. Another incremental improvement.
About a year ago I tried to add ferro-fluid to the horn drivers (they don't have any in the stock configuration) and it made things worse(!)- not what I was expecting; but in hindsight it altered the resonant frequency and changed the mechanical characteristics in such a way that it was no longer compatible with the crossover as designed. I cleaned it out and things were back to normal.
This put things back in balance and I enjoyed them this way for about 5 years. Until yesterday.
Though these speakers always sounded (and measured) nice and flat I would get fatigued after listening for about an hour or so, depending on music (the more simple acoustic stuff I could listen longer). There was an in-your-face quality that I didn't realize was there until after I did the
crossover mod.
I read about how Dean G. modified someone's RF7II crossovers to great effect with just a handful of components so I thought I'd give it a whirl.
The layout is 3rd order on the tweeter and 2nd on the bank of 3 woofers. I ordered enough components to replace all the caps and resistors on the tweeter board and bypass caps for all the main filter caps but not the zobel caps.
I was going to replace all the resistors in the zobel networks but only ended up replacing the series pads in the tweeter network. I ordered Mills for the series resistors and Dayton audio grade for the zobels. I measured and compared the inductance of the stock resistors and they were exactly the same as the 'low-inductance' ones I purchased, so I left them in. Interestingly, the Mills 5-ohm resistor and the generic 5-ohm cement I was using for the external 'pad' measured exactly the same too. :scratch2::scratch2:
So after the modification I listened to a Pablo Today Basie album that I'm familiar with and here are my initial impressions:
At first there was a murky haze but this lasted less then a minute. Maybe my amp wasn't all the way warmed up. Then I noticed that, with the volume set to were I usually play music it didn't seem as loud.. and that I could hear 'into' the music more, there was more 'space' between notes, more silence. I could hear reverb tails deeper and transients seemed sharper. And the soundstage - I hadn't really heard it before, now stuff was over here, over there and back over there.. It's hard to describe without going into a bunch of audiophile lingo but even my wife commented on how good the sax sounded (she was first chair tenor all 4 years in High School jazz band).
I'll post pics and schematics after a bit but the wife just left so I'm going to go play some more music..
